Citroen C5 1.6 HDI Turbo
floggmolly
Unread post by floggmolly »
I have a 1.6 HDI C5 the turbo packed up. I got a brand new turbo delivered today. There is slight play in the propellor/turbine is this normal? Is this ok to fit?
Lighty
x 35
Re: Citroën C5 1.6 HDI Turbo
Unread post by Lighty »
There will be a very small amount of play,but not much. Make sure you determine why the old one failed, or the new one could fail in less than 1 mile
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
floggmolly
Thanks for the reply it was very useful. The last one failed due to bad oil. What oil should i use? I have been using 5W-30 low sap VW Spec
Citroenmad
x 110
Unread post by Citroenmad »
floggmolly wrote:Thanks for the reply it was very useful. The last one failed due to bad oil. What oil should i use? I have been using 5W-30 low sap VW Spec
You ideally need to use Total Ineo ECS, its a oil made by Total for the PSA 16v HDi engines with FAP filters.
You should also change it every year or 10-12K (I do mine every 7-8K), not the stated 20K, as this is where the problems begin ...
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
floggmolly
Thanks..is that miles or kilometres?
x 5663
floggmolly wrote:Thanks..is that miles or kilometres?
That will be miles!
Divide by 0.6 for Kilometres
Lighty
x 35
When we do a turbo on any 1.6 hdi, we always remove the metal gauze filter that is at the engine block end of the feed pipe. It is very fine and gets blocked. My theory is that some dirty oil is better than no oil.
Its a real pita to get the pipe off though, but better than wrecking your new Turbo. Most turbo manufacturers demand a new feed pipe to honour the warrant anyway.
Citroen C15
Citroen Ami
