Activa keypad
Stekelly
Activa keypad
Unread post by Stekelly »
Finally got around to getting back to doing work on the activa . The battery is dead from sitting the last while and I've a booster connected . When i turn the key to the power on and try enter the code on the keypad nothing happens. The red and green light are lit when i turn the. Key to there but neither does anything when i enter the code. I'm probably missing something simple but can't see it.
Any ideas?
Deanxm
x 87
Re: Activa keypad
Unread post by Deanxm »
From memory i think if both lights are illuminated then there is a fault with the immobiliser system, first of all get the battery charged and fitted correctly, high or low voltage a generaly dodgy batteries are responsible for all sorts of strange goings on, leave the car disconnected from any power for half an hour then reconnect the battery, lock, unlock, lock, unlock the car with the blip, once this is done try starting again.
There could be a bad contact on the double injection relay (big brown relay by the ecu box) especialy if she has been sat around doing nothing for a while, but get a good battery on her first and try then.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
davoxx
x 15
Re: Activa keypad
Unread post by davoxx »
don't have a 'smart' charger/booster connected when you are trying to use start a car, it can fry the electronics as well as preventing it from starting.
the battery may be too flat. best to use jump leads, or a charged battery.
why?
Stekelly
Re: Activa keypad
Tried it again todaywith jump leads to a Defender.Still the same story. The handbrake light stays on even though its now off (it was sticking at first but a bit of a push sorted that) and the oil light as well as the little orange one on the coolant temp.
Havnt got in to the other Xantia to check but from memory does the oil light not go out before you start it or at least when the ignition starts turning over?
Xantidote
x 5
Re: Activa keypad
Unread post by Xantidote »
I wouldn't expect an oil light to go out until the oil pump develops at least a bit of pressure, meaning a bit of cranking if the engine doesn't fire up. Although normal oil pressure on an older (classic) car might have been 30-50 psi, the oil pressure to cut out the oil pressure warning lamp would be triggered at (if memory serves me right) about 4-8 psi. Can't imagine it's much different on more modern vehicles.
Martin
1995 Xantia TDLX (deceased :( )
davoxx
x 15
Re: Activa keypad
Stekelly wrote:Tried it again todaywith jump leads to a Defender.Still the same story. The handbrake light stays on even though its now off (it was sticking at first but a bit of a push sorted that) and the oil light as well as the little orange one on the coolant temp.
after you start it, not while you crank or before.
why?
