power steering pipe
rocenante
power steering pipe
hi guys any info would be great,looking to get a power steering pipe for my xantia will prob have to have it made up .what price should i be looking to pay
its the one under front centre about 12 inches long
- x 94
Re: power steering pipe
if you send me the last 8 digits of your Chassis/VIN No. i will get you a price and part No. from service citroen ( dealer's )
and it if you can describe were the pipe goes from/to,
or you could try Martin at Pleiades Sawtry Camb's on 01487 831239
regards malcolm
regards malcolm
citroenxm
- Fallen Hero
- x 70
You should know that Malc, the useual PAS Feed pipe that runs along the subframe edge behind the engine.. All the S2 cars had NON coated pipes which rust through if theres no oil leak to coat the pipe...
S1 pipes are coated for some reason.. It will be the single Long pipe from the PAS pump right round past the regulator, into a rubber flex onto the chassis round the gearbox end, down the side of the subframe leg, along the bottom edge across to the Pinion valve.. S1 and S2 with anti sink are all simmilar if not the same and should do the job.
It IS possible to remove this pipe and refit with a bit of jiggleing while the engine and box is in place. I did it on a DERV Auto, and they are a bigger box!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
davetherave
- x 4
I wonder if it would be possible to get someone like pirtek to make up the rubber part of it to replace it.
When the one on the xantia went I made up a copper pipe without the rubber part, it works fine but you can feel the vibration in the steering wheel even with a couple of coils in it.
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
GPZ500s
rocenante
cheers for the replys guys sorry for the delay been away and then been using the wifes car
.But pirtek made up hose and all fitted it was a pig of a job to fit so another xant back on the road
rocenante
forgot to say the price for the pipe was 55 in total
