Clutch judder, 1.4 C3.
Patt
Unread post by Patt »
Hi, I have recently aquired a 2003 C3 1.4 with a slightly juddering clutch. Careful driving can minimise this, but I don't want to pull it apart at present.
Has anyone any tips to "cure" it?
Thanks.
Lighty
x 34
Re: Clutch judder, 1.4 C3.
Unread post by Lighty »
Not a very strong clutch in this car as its a relatively low output, the only cure will be a new one I am afraid.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
x 94
Unread post by citronut »
if its juddery on take up it might be the bitting point is near the top of the peddle travle, in which case the clutch could be on its last legs,
i dont think the C3 had an ajustable cable or self adjusting or even hydraulic'ly operated,
if the later two it wont be adjustable, so a new clutch will be required,
if its like all the older TU engined cars its nit a very dificulte job at all,
regards malcolm
Patt
Hi, thanks for that. It is hydraulic ,so self adjusting, and pedal movement is smooth and travel normal.
