Which clutch ?
froggy
- (Donor 2026)
- x 4
Which clutch ?
Hi, Iam about to buy a clutch for my series 1 Xantia . Where should I get it from, would it be best from my local Citroen dealer or from local motor factor ? Someone told me it would be wise to buy oil seals as well, while doing the job. is this true ? any help greatfully received, Cheers Terry .
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Lighty
- x 34
Re: Which clutch ?
Valeo or LUK clutch , any other will not be as good. If you get a genuine Citroen one, it will be either of these.
two new driveshaft seals would be a good idea.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 94
Re: Which clutch ?
and mind you only fit BV spec gear oil
regards malcolm
regards malcolm
ken newbold
- x 4
Re: Which clutch ?
Where to buy it would depend on where you are, I buy mine from Malcolm Lockwood in Bradford, or you might try GSF.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
