Xantia II - After market Oxigen sensor
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Can any aftermarket Oxygen sensor be used as a replacement to the genuine one, given it has four wires and the same connector that is plugged onto the ECU.
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Provided it has the same "snout" then yes they interchange fine.
x 94
Re: Xantia II - After market Oxigen sensor
Unread post by citronut »
should be ok although i have had what was spozed to be an OE quality one from ECP that still caused the car to fail the emmisions on the re/test,
substanderd equipment comes to mind,
the others to avoid are the universal type you patch the original plug to
regards malcolm
