My 2005 1.6 Hdi (137,000 miles) broke a valve. Cylinder head, piston and bore damaged. My mechanic suggested a used replacement engine. I have had an offer of a low mileage 2010 1.6hdi at a good price. What I want to know is will this much newer engine be a straight replacement for the 2005 one or are there going to be problems with electrics and sensors etc.
Thanks,
Nmet
C5 - Engine replacement - advice needed!
SaabC5
Re: C5 - Engine replacement - advice needed!
You would need to find out the exact engine type code to know for certain. Even then you could find Citroen have changed certain parts for different manufacturers and consequently have changed some plugs/leads. Can you not view the engine and do a direct comparison (take photos)?
09 C5 X7 2.0Hdi Exclusive in Perla Nera black (the best colour)
cachaciero
- x 9
I would want to know what ECU was used on the new engine and a check of sensors would be good too.
I think that you do need to be sure that the engine will work with your ECU, changing the ECU is likely to be a bigger minefield than changing the engine.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Citroenmad
- x 110
Was this due to cambelt failure?nmet wrote:Hi,
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
Lighty
- x 34
I recently fitted a Ford Focus 1.6 HDI in a Picasso, engine codes were identical, but fuel pipes and pump fittings were different, we got it all working in the end, but believe me it was a BIG job, the 1.6 is a very fiddly little unit.
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
nmet
- New User
Citroenmad wrote:Was this due to cambelt failure?nmet wrote:Hi,
No, new cam belt at 127K. car regularly serviced by dealer at 10k intervals. I think I was just unlucky!
