Currently stripping all useful bits of my 98 1.9 406td estate before iit goes to meet its maker and its got about half a tank of fuel in. This would obviously be better in my wifes citroen than a tank at the breakers.
Whats the easiest way to get it out?
TIA
Draining diesel 406 estate. Help please
spider
- x 77
Re: Draining diesel 406 estate. Help please
We used to have an old Cavalier fuel pump (as they were external) with a length of pipe on inlet / outlet and used that to empty tanks (mixed fuel usually) via either the fuel pipe on the bulkhead or in some cases the filler pipe itself.
Does it actually run OK ? If it runs it may be easier to disconnect the fuel pump return pipe and have that into a suitable container, not tried it this way but its reasonably easy.
Andy.
- x 1238
If you can get it above ground level you can disconnect the feed pipe, bend it downward and place it in a suitable container, jacking the rear up will help.
DickieG
- Monaco's youngest playboy
- x 38
Remove the fuel gauge sender unit assembly from the top of the tank then syphon the diesel out with a length of hose, diesel tastes a lot nicer than petrol
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
spider
- x 77
As usual I forget the obviousDickieG wrote:Remove the fuel gauge sender unit assembly from the top of the tank then syphon the diesel out with a length of hose
I will have to take your word for it I've not sampled any derv (thankfully) petrol yes ended up accidentally swallowing some years ago.DickieG wrote: diesel tastes a lot nicer than petrol
Andy.
a4gom
Cheers guys a few options there, the car won't run (broken cam) I had considered connecting a pipe to the filter side of the prime bulb, dropping the pipe into a container and pumping the bulb until it started flowing. I was hoping this would start a syphon?
DickieG
- x 38
I've found that that doesn't work presumably due to the one way valve restricting the free flow.a4gom wrote:I had considered connecting a pipe to the filter side of the prime bulb, dropping the pipe into a container and pumping the bulb until it started flowing. I was hoping this would start a syphon?
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Xaccers
- x 185
Yup and it takes a looooonnnnng time to empty the tank just using the primer (guess how I know?)DickieG wrote:I've found that that doesn't work presumably due to the one way valve restricting the free flow.a4gom wrote:I had considered connecting a pipe to the filter side of the prime bulb, dropping the pipe into a container and pumping the bulb until it started flowing. I was hoping this would start a syphon?
DIY sphere tool
DIY sphere tool
a4gom
Looks like sender unit option it is then.
xmexclusive
Put washing up bowl under tank.
Drill or punch hole say 10mm in tank at lowest point.
Remove fuel cap to fill bowl fast.
My training was free and god help em if I catch them.
John
John
Xmexclusive
a4gom
I'll stick with getting it out of the top, i don't have a washing up bowl and would probably need more than one. I don't need the mess either, having said that the cars at my parents not mine.
