Hope you don't mind me sneaking over from the citroen side!
Mothers got a 307 SW 1.9HDi on a 53 plate, cars only done 40k (she bought it with 32k), she mentioned its been slow starting, so I suggested counting to to ten after the glow plug lights out which has meant apart from the latest cold spell its fired up First turn, last couple of mornings when Really cold has taken a couple of goes to get going, normally fires up on the 3rd attempt,
I wondered if the pre heaters not working quite so well?? Or if the battery doesn't Quite have the grunt to fire it over fast enough when Really cold??
Any thoughts or ideas what may be causing it?
Many thanks in advance,
Timmo.
