DRILL PRESS:A tall upright machine useful for suddenly snatching flat metal
bar stock out of your hands so that it smacks you in the chest and flings your
beer across the room, denting the freshly-painted project which you had
carefully set in the corner where nothing could get to it.
> >WIRE WHEEL:Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light . Also removes fingerprints and hard-earned
calluses from fingers in about the time it takes you to say, 'Oh s**t!'
> >SKIL SAW:A portable cutting tool used to make studs too short.
> >PLIERS:Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
> >BELT SANDER:An electric sanding tool commonly used to convert minor touch-up
jobs into major refinishing jobs.
> >HACKSAW:One of a family of cutting tools built on the Ouija board
principle... It transforms human energy into a crooked, unpredictable motion,
and the more you attempt to influence its course, the more dismal your future
becomes.
> >VISE-GRIPS:Generally used after pliers to completely round off bolt heads. If
nothing else is available, they can also be used to transfer intense welding
heat to the palm of your hand.
> >OXYACETYLENE TORCH:Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside the
wheel hub out of which you want to remove a bearing race.
> >TABLE SAW:A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
> >HYDRAULIC FLOOR JACK:Used for lowering an automobile to the ground after you
have installed your new brake shoes , trapping the jack handle firmly under the
bumper.
> >BAND SAW:A large stationary power saw primarily used by most shops to cut
good aluminum sheet into smaller pieces that more easily fit into the trash can
after you cut on the inside of the line instead of the outside edge.
> >TWO-TON ENGINE HOIST:A tool for testing the maximum tensile strength of
everything you forgot to disconnect.
> >PHILLIPS SCREWDRIVER:Normally used to stab the vacuum seals under lids or for
opening old-style paper-and-tin oil cans and splashing oil on your shirt; but
can also be used, as the name implies, to strip out Phillips screw heads.
> >STRAIGHT SCREWDRIVER:A tool for opening paint cans. Sometimes used to convert
common slotted screws into non-removable screws and butchering your palms.
> >PRY BAR:A tool used to crumple the metal surrounding that clip or bracket you
needed to remove in order to replace a 50 cent part.
> >HOSE CUTTER:A tool used to make hoses too short.
> >HAMMER:Originally employed as a weapon of war, the hammer nowadays is used as
a kind of divining rod to locate the most expensive parts adjacent the object we
are trying to hit.It is especially valuable at being able to find the EXACT
location of the thumb or index finger of the other hand.
> >UTILITY KNIFE:Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents such
as seats, vinyl records, liquids in plastic bottles, collector magazines, refund
checks, and rubber or plastic parts. Especially useful for slicing work clothes,
but only while in use.
> >SON-OF-A-BITCH TOOL:(A personal favorite!) Any handy tool that you grab and
throw across the garage while yelling 'Son of a BITCH!' at the top of your
lungs. It is also, most often, the next tool that you will need.
> >Hope you found this informative.
> >THINK SAFETY
regards malcolm
usefull tips
- x 8298
Timmo
- x 168
Re: usefull tips
brilliant and So true!!!
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
addo
- Sara Watson's Stalker
- x 95
