Xantia ABS Block Bleeding
DHallworth
x 170
Unread post by DHallworth »
Hi Guys,
I'm about to replace 2 hydraulic pipes that are coming out of the ABS block on an S2 Xantia and on another S2 Xantia I'm about to replace the entire ABS block.
Does this block need to be bled to remove any air in any specific way or is bleeding the brakes enough to suffice?
David.
'98 Xantia Activa V6 :-D
'13 Renault Zoe - Broken
'15 C4 BlueHDi Feel - For Sale
x 8457
Re: Xantia ABS Block Bleeding
Just normal bleeding is absolutely fine David, the Xantia ABS system works in a totally different way to the pumped systems found on conventional cars.
the Xantia block simply contains three electrovalves to modulate the LHM flow to the calipers. They're wide-open under normal circumstances and thus fully bleedable by the normal method.
DHallworth
x 170
Thanks Jim, that's great to know.
David.
