C5 2.2 Diesel Fuel Pump
MarkC5
Unread post by MarkC5 »
Does anyone know where the fuel pump is, if it is easy to change and how you do it please........I'm not a car person but am trying to learn without the workshop manual that isn't available for my car.
bikerbadge
Re: C5 2.2 Diesel Fuel Pump
Unread post by bikerbadge »
hi there well i got a 2.0 hdi so im guessing there in the same place ...... lift up the rear seats and there should be a black plastic disc lift that up and the fuel pump is in there, i changed mine not long ago and theres a post all about it with all the info you need n its easy to do too lol
"92" Citroen ZX
"93" Citroen ZX
"97" Citroen ZX
"02" Citroen C5 (current)
and various other makes n models
x 1061
Unread post by wheeler »
There are 2 fuel pumps on the car the low pressure one is the one bikerbadge is talking about & there is also a high pressure one on the engine which is driven by the timing belt, removing & refitting this one is probably not for a complete novice.
KevMayer
Unread post by KevMayer »
Hello MarkC5,
Why do you need to change the pump?
What problem do you have?
Cheers, Kev
MarkC5
Hi Kev
Did say I was learning I mean't the fuel filter which I just assumed would be good to change as you do like the air filter and oil filter when the oil is changed.
Sorry everyone, that I mean't filter and not pump.
Mark
KevMayer
The fuel filter is easy to change. It's in a black plastic container at the front of the engine on the left. It's next to the fuel pump. The filter housing is around 80mm dia by 100 mm deep and has fuel pipes connected to pipes on the housing lid.
The problem is that there are two types of filter, one is Bosch the other Siemens. On my 2.2 Hdi it's a Siemens filter even though the rest of my fuel system is Bosch.
To find out which I had, I removed the filter element and compared it to filters on ebay.
So, first thing is to find out which filter unit you have.
Cheers, Kev
MarkC5
Thanks very much Kev
KevMayer
There's an easier way to tell if the fuel filter is Bosch or Siemens.
A Bosch filter housing has two pipes on the lid.
A Siemens housing has three pipes on the lid.
Siemens
http://img.auctiva.com/imgdata/1/1/1/6/ ... 4073_o.jpg" onclick="window.open(this.href);return false;
Cheers, Kev
MarkC5
Thanks Kev
