Hi All,
Just bought a 95 1.9TDLX with 158k on the clock, and the only thing i can find wrong with it is a strange noise from the steering when applying more than half a turn of lock either way; like a squelching noise. There doesn't appear to be any notchiness i might expect with a duff rack, but the car hasn't been moved for a couple of months. Is it just air in the system (I intend to do a full LHM flush soon, anyway), or something a little more sinister?
Phil
Xantia Noisy Steering
blueboy2001
Its sounds to me like its just the HP pump operating to pump oil to the rack to provide the power assistance. Could possibly be symptomatic of a flat accumilator sphere - listen for regualar ticking at idle on the flat with no weight in the car.
On the 95's they don't have the flow divider found on earlier models; the rack has its own feed direct from the pump so theres not a lot to go wrong.
Dave Burns
- x 3
I think what you are hearing is just a trait of the xantia, mine also does it.
Its a feint hissing sound that gets transmitted up the steering column and then appears to come from the wheel its self.
This hissing sound is caused by the high pressure oil being forced through the ports in the pinion valve, from the straight ahead position relatively little pressure is required to move the wheels and the ports in the valve remain quite wide allowing oil to escape easily.
As the angle of the wheels increase the mechanics of levers and fulcrums becomes less efficient, more hydraulic pressure is then required at the piston, to increase this pressure the relationship between the inner and outer rotors of the valve change, reducing the size of the ports that the oil has to go through to escape the valve, the smaller the port becomes the louder the hiss.
Ever put you thumb over the end of a hose pipe, as the water is forced out faster it creates noisey jet, same thing here just more intense.
Dave
Dave
nick
alexx
