xantia 1.9 td stiff steering
reservex
Unread post by reservex »
Xantia steering goes stiff intermittently seems better in the wet any ideas what is causing this? :?
1999 Xantia Estate 1.9TD
wotwot
(Donor 2021)
x 4
Re: Xantia 1.9 td stiff steering
Unread post by wotwot »
I suppose the obvious would be checking the green blood level,and also checking the aux belt is tight enough.
x 1240
Unread post by Peter.N. »
I would second that.
imperial21
Unread post by imperial21 »
I would say wd40 / spray grease the steering rack universal joint, mine started like that and got far worse !
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Xaccers
x 188
Unread post by Xaccers »
Also check both ends of the LHM feed pipe (rubber pipe from the resevoir to the pump) are very tight and there are no splits letting in air.
DIY sphere tool
reservex
Thanks guys will give them all a try and report back !
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Firstly it will be the UJ joint.... Most highly likely, as they do sieze up and Ive had a few do it now.
Secondly.. check the LHM fluid Filter, as THIS FILTER near the bottom of the page was found to be restricting mums PAS on her Xantia! The circular filter.
A very sad...
1994 XM 2.1 d auto
reservex
Thanks for all your input guys, tried all, the one that worked on this was a good dosing of wd40, back to normal thanks
citroenxm
Fallen Hero
x 70
Yup the useual UJ.. KEEP on top of that joint give it a dose once a week to help loosen it up..
Sounds like you caught it just in time, they can get that bad that even a dose of WD wont help, and it needs removing from the car to free up properly..
Nice One!
A very sad...
1994 XM 2.1 d auto
