51 plate laguna 1.9 dci, headlights
ARGYLE47
Unread post by ARGYLE47 »
Hi, i was wondering if anyone can help, my front nearside headlamp does not come on. When i turn the lights on it flickers then nothing, the offside light is ok, i have Xenon lights and hope it is the bulb only as i've heard this is quite expensive to replace the bulb and ballests and not a job for the diy'er, cheers for any help
SaabC5
Re: 51 plate laguna 1.9 dci, headlights
Unread post by SaabC5 »
Swap the bulbs around, if the faulty bulb works on the offside you know the nearside ballast has gone. If it doesn't work then the bulb is indeed faulty.
R9UKE
x 3
Unread post by R9UKE »
I'm afraid it does sound like the ballast failing to be able to ignite the bulb
French is best.
