HP PUMP ALIGNMENT
KennyW
x 163
HP PUMP ALIGNMENT
Unread post by KennyW »
Hi Guys,
My pump is out of alignment with the rest of the Aux belt pulleys.
On fiddling this morning it would appear the spacers are preventing it to sit correctly
Item No 5
Has anyone any suggestions, i was thinking about reducing their size or changing the type of 'nuts'.
Kenny
C3 1.4 petrol (SWMBO)
artdjones
Re: hp PUMP ALIGNMENT
Unread post by artdjones »
I had the same problem.It seemed like fiddling with the spacers would help but it didn't.I got a S/H pump for a HDi through ebay and it fitted perfectly.A few months later we needed a pumpfor a 1.9TD at work.My old pumpfitted perfectly.Maybe you have the wrong pump fitted?
x 94
Unread post by citronut »
are you sure its the pump out of line and not the tensioner leaning over with a shot bearing
regards malcolm
KennyW
x 163
Its the pump out of align, you can see the rest of the set is fine.
artdjones, I was thinking the same thing :!:
I'll check citroen service site>
Kenny
KennyW
x 163
Hi all,
Just confirmed from service citroen site
HP pump 2.0 HDi 90hp 4007Y6
HP pump 1.9 TD 90hp 4007T7
Also the brackets which hold the HP pump, alternator and Fuel pump are of a different design hence the alignment problem.
Kenny
KennyW
x 163
Hi All,
As anyone got both types of brackets off the vehicles concerned and can measure the distance between them.
My curiosity has got the better of me.
Also is the 110 the same as the 90 (2.0 HDi)
Kenny
x 94
did you enter you chassis/VIN No. whilst you were on service citroen, as that should give you the exact part No. for the bracket that is ment to be on your car,
then if your lucky you might find a part No. on the bracket that you have
regards malcolm
KennyW
x 163
Hi Malcolm,
I've still have the chassis no of my 1.9TD so i can do a direct comparison.
I was just wondering if anyone had both types stting around :) doing nothing so they could mearsure the distance between the brackets where the HP pump is connected.
I'm going to try and remove the spacers and insert washers of the correct size and see what happens.
Kenny
addo
Sara Watson's Stalker
x 95
Unread post by addo »
It's worth noting the correct orientation for assembly is NOT as shown in the SC diagrams. This is the correct way round for the flanged expanding sleeves:
KennyW
x 163
Adam,
Thanks for the reply.
The sleeves are fitted as per the SC diagram that may explain everything i shall turn them around and see what happens
Kenny
x 94
wow Adam a bone dry XANT pump :shock: :shock: :lol: :wink
regards malcolm
addo
x 95
Of course! It's not hard to get right.
x 94
it must be due to the upside down atmospheric presure down under :shock: :lol: :wink:,
or the gravity working ass about face
regards malcolm
KennyW
x 163
Malcolm,
I think I will change my pump around just like Adam's :lol:
Kenny
KennyW
x 163
Hi All,
I've just spoken to Martin @ Pleiades and he has clarified the issue with the HP Pump.
There is a diference of 5mm between the pump and the pulley hence the alignment issues.
Otherwise the pump internals are the same :roll:
Kenny
