Citroen c5 2005, rear suspension stuck after wheel change
fredoj
Unread post by fredoj »
I jacked up the rear of my citroen (c5, diesel, 2005 model, must be on hydractive III ) to change the wheels, upon completion, the rear suspension would not come down, I am not sure but when it was jacked up, I might have pressed the down button. Do you think this confused the computer system? or something is dislocated?
The height switch button in the car is working and is able to raise and lower the front suspension
There are no error messages on the control panel
I took it to a local garage that claims they are the only citroen dealers in the country, but they could not touch it claiming they are used to other suspension but this one is electronic
i am on a mission to find a solution myself, I know I cannot get underneath the car for safety reason so will have to take it to a ramp
What should I look for? I am assuming probably a mechanical arm is dislocated and therefore the height control valve on the rear is not receiving instructions, or it could be the spheres that need replacement (it was making some noise prior to that)
could someone post photos of what the underneath of a Citroen c5 2005, hydractive ||| looks like for comparison purposes?
x 94
Re: Citroën c5 2005, rear suspension stuck after wheel chang
Unread post by citronut »
im not 100% sure on a C5 but maybe you jacked on somthing you should not have, i do know there is nout under the centre at the rear to jack the car up by,
were exactly did you place the jack,
it will be perfectly safe to get under there as long as you place some blocks of wood or somthing under the subframe, to stop the car dropping/squashing you,
regards malcolm
Citroenmad
x 110
Unread post by Citroenmad »
The spheres wont cause any difference in the cars height or ability to change heights. So thats one thing you can rule out, they also wont produce a noise when they are nearing the end of their life. A nocking or banging from the back of the car will often be a radius arm bearing.
Have you driven the car since you jacked it up? It might well just sort itself out. If not then possibly its the rear heights corrector. Though it is electronic on the C5s it still has similar arms to the Xantias etc. If not then id be looking on a Lexia to see if I can get the suspension moving via that.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
hi Fred and welcome.
hope you can sort this ok.. I can't really help as have never been under a c5
John
x 2941
Is it possible that you jacked the car up with the jack under the torsion bar? If so you may have moved the height adjuster clamp around on the bar or broken/disconnected the height adjuster link.
x 5651
It is recommended that the C5 is at maximum suspension height before lifting it with a jack.
Try doing a set of Citroebics, may correct itself.
dnsey
x 19
Unread post by dnsey »
Just like the earlier cars, the height sensor is connected to the ARB via a 'dog bone', which can detach itself. Is yours still in place at both ends?
cachaciero
x 9
Unread post by cachaciero »
I have had this myself when trying to set ride heights, in that setting the height in normal position if that position is a little high and you then go to high it won't come back, I surmised that the input sensor range over which the computer would accept as valid data was very limited and once outside this it latched the current height BUT that is speculation. Once I got the sensor set so that normal was a tad low it worked fine, correct ride height was then established by setting the height in the ECU using the Lexia.
There does seem to be two ways of setting ride height i.e mechanical adjustment and altering values in the ECU and I am sure there must be some relationship but none of the documentation I have clarifies this.
I am sure that if the O/P had access to a Lexia and could depressurize the system it would all come good, failing this moving the sensor connection on the roll bar until the system is back in control is the only way to go.
Jacking the car and then selecting high may well confuse the system in that with the way weight is distributed the system in attempting to go high may go beyond the sensor limits set in the system, bearing in mind that unlike earlier hydraulic Cits that max high as max low is not the max movement possible in the cylinders / mechanical linkage.
CAVEAT much of what i have said here is speculation my guess and not to be taken as the gospel truth.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
Richard_C
(Donor 2026)
x 224
Unread post by Richard_C »
If it is a computer problem, there is a slim chance you could cure it like this:
Check you have your radio code (if indeed one is needed)
Disconnect the battery + terminal
Now the hard part: Make a pot of tea, drink tea, eat biscuit, relax, read the paper, whatever.
After 20 or 30 minutes, reconnect the battery.
Logic would suggest that the suspension lever should be set on high at this point, but logic and cars often don't mix.
With great good luck the ECU will have forgotten everything it has ever known and teach itself all over again from scratch. Has worked for me with an auto box rough changing problem. Might apply to the suspension brain as well. Depends what is stored in ROM and RAM, at this point my mind goes blurry so don't seek explanation. It's free to try, apart from the cost of the tea and biscuits.
Richard_C
Chris570
x 36
Unread post by Chris570 »
just to add to that, you're meant to have all the doors closed and wait sometime before disconnecting the battery. a good idea to leave the drivers window open as well
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
fredoj
Re: Citroen c5 2005, rear suspension stuck after wheel chang
If anyone has a problem like this, look at mechanical element first, I should have checked for the mechanical arm movement first, because it was mechanically stuck , so try and make sure nothing is preventing free movement of the arm
