best price EOLYS fluid
- x 94
im sure this has probably bin asked before,
were'z the best/cheapest place to buy the stuff
and is it best to use a proper filling kit???
regards malcolm
regards malcolm
- x 8457
Re: best price EOLY fluid
I don't know the answer to the first but on the second point I believe it's very nasty toxic stuff and needs to be handled properly so yes, on that basis the proper filling kit will be essential...
- x 94
ok thanks hunny
and have you abandonded your DIS-LEXIA2 now you have a new toy
regards malcolm
regards malcolm
- x 5688
Re: best price EOLYS fluid
I'm sure there will be adequate warnings on the container if applicable but:
The stuff in Eolys is Cerium(III) oxide:
There also seem to be two different Eolys fluids the are not compatible.
There is also an after-market alternative from JLM
But that is Cerium.Cerium, like all rare-earth metals, is of low to moderate toxicity. Cerium is a strong reducing agent and ignites spontaneously in air at 65 to 80 °C. Fumes from cerium fires are toxic. Water should not be used to stop cerium fires, as cerium reacts with water to produce hydrogen gas. Workers exposed to cerium have experienced itching, sensitivity to heat, and skin lesions. Animals injected with large doses of cerium have died due to cardiovascular collapse. Cerium(IV) oxide is a powerful oxidizing agent at high temperatures and will react with combustible organic materials. While cerium is not radioactive, the impure commercial grade may contain traces of thorium, which is radioactive. Cerium serves no known biological function.
It seems to be a dealer only part although it may be cheaper at the Peugeot dealer.A major technological application for Cerium(III) oxide is a catalytic converter for the reduction of CO emissions in the exhaust gases from motor vehicles. In particular, cerium oxide is added into Diesel fuels. Another important use of the cerium oxide is a hydrocarbon catalyst in self cleaning ovens, incorporated into oven walls and as a petroleum cracking catalyst in petroleum refining.
Dommo
- x 20
I found the stuff at euro car parts so it might be cheaper there.
Monkeyfeet
How about not buying any at all? An alternative is to spend £15 for a Galetto cable from Ebay to help reprogram and then knock out the filter completely. I did just that last weekend and am aiming to post details when I've clocked up 500 miles DPF/ FAP (and therefore Eolys free). In the meantime I can say that it's reasonably straightforward job, if you have any questions I'll do my best to answer.
XantiaTD's(all gone). BXGTi, sold (sob). C5 2.2Hdi SE Exc Hatch. C5 2.2 Estate auto. Xsara Hdi estate. Yam YZF750, Zoom. GSX-S750, mmm.
cachaciero
- x 9
Ah! but what happens at next years MOT (or even this year if after March).
see http://uk.autoblog.com/2012/01/04/chang ... you-ready/" onclick="window.open(this.href);return false;
Note the bit about missing catalytic converters and "inapropriate mods"
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Lighty
- x 34
The lack of a FAP filter cant really be spotted if you knock the middle out of the particulate filter, so the mot thing is a red herring in my opinion.
If you need cheap fluid, GSF is cheap for their fluid, I think it is called Pat fluid or something similar, my local factors, SDL are cheapest, at £59 +vat for 5 litres.
Interested in this Galetto cable, tell me more
Dacia Duster 1.5 dci
Renault Twizy Technic
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 8457
Not quite Malcolm. It's in retirement though and awaiting a particularly quiet, rainy day for another look-see. We've not had a lot of rain yet so no look-seecitronut wrote: and have you abandonded your DIS-LEXIA2 now you have a new toy![]()
One day...
yeomills
My C5 Mk11 2.2 HDI has done 73000 so am expecting the low Elois warning soon. I have already purchased the fluid and await a good day to top up. My question is can the lexia reset the system so I dont go into limp mode. I purchased a Lexia and am looking around for a suitable laptop to link to.
Barry
Barry
Lighty
- x 34
Your Lexia certainly can reset the system, it is a little tricky till you get the hang of it. The process is not very self explanatory, but not too bad, and you cant really break anything in my experience.
I always tend to go into Injection, then parameters, then particulate filter and check the pressure differential 1st to see how blocked the FAP is before doing anything.
In my experience you want 0 mb at idle, certainly no more than 5mb, and about 60mb at 3000 rpm, certainly no more than about 80mb, if so the filter is getting blocked.
Hope the learned folk on here agree with this
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
- x 94
you are aware there are two types of particulate fluid early and late types, which you must use to corect one for your car,yeomills wrote:My C5 Mk11 2.2 HDI has done 73000 so am expecting the low Elois warning soon. I have already purchased the fluid and await a good day to top up. My question is can the lexia reset the system so I dont go into limp mode. I purchased a Lexia and am looking around for a suitable laptop to link to.
Barry
your car being a MK2 i should be the later type which i think they dont call EOLY's,
cant remember at the mo what they call it, but i do know it must not be mixed,
also i think im right in saying the early system has a float in the tank to indicate the level, and the later system has an electronic counter,
if the earlied system is topped up before the empty warning pops up you dont need to re/set the computer/memory,
and i nthink the later system you can get away without a DIS-LEXIA setion,
regards malcolm
Lighty
- x 34
The fluid is now called Infinium by PSA, the old cars used DPX 42, and the filler lid is white, newer cars have a green lid and use Eyloys 176 (may be spelt wrong
All cars calculate electronically, and dont actually "know" how much fluid is in the tank. I cut an old C5 tank apart, and it has a low level sensor, this seems to corrode badly, and will often jam so the system warning light cannot be put out
Citroen C15
Citroen Ami
Citroen C15
Citroen Ami
Monkeyfeet
Re the Galletto cable. The cable itself connects to the cars ecu in the same way as Lexia does, ie car com port to laptops usb.
Then there are following stages:
1.Connect to car and the Galletto program is used to extract the file that is the ecu's map/program to the laptop.
2. Modify the file to de-fap it. You will need a program such as Ecusafe for this. OR get someone who has this prog to do this for you (it's only around 500k)
3.Send the now modified file back to the ecu, again using Galletto.
4.Don't forget to bash out the filter!
Might sound worse than it actually is, to me it's a whole lot easier than messing around with fluid and retaining the FAP with it's associated regenerations on a ten year old car.
I can do this in more detail if needed but please bear in mind my earlier comment about wanting to get more miles on the clock post de-fap, as doing so will mean this will carry more weight when the car has done 500 miles or so. Talking of weight, that filter is pretty heavy!
This is type of cable I bought (this is just a sample that I've just seen on eBay):
http://www.ebay.co.uk/itm/Galletto-1260 ... 46001fdaa9" onclick="window.open(this.href);return false;
Hope this helps for now and that it isn't too far off-topic. (could start another thread)
cachaciero
- x 9
Indeed you are correct however a particulate analyser stuck up the exhaust would tend to give the game awayLighty wrote:The lack of a FAP filter cant really be spotted if you knock the middle out of the particulate filter, so the mot thing is a red herring in my opinion.
I
cachaciero
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
