Thanks for posting up the part number Dom
Dommo wrote:A little word of warning when you do replace it, I'm sure there's something inside that has a habit of trying to fall out when you remove the hexagon, and a lot of LHM can come out if you're slow at replacing it, so unscrew it and keep someone handy to either plug up the hole with something or get them to swap the o-ring as you plug up the hole!
Not 'alf on both counts
There's a spring, a ballcup, a ball and a piston all ready to make a bid for freedom and as you say Dom, it'll bleed LHM like a stuck pig and that's not good for the alternator.
To save loosing the spring and it's friends, when you unscrew the hexagon, keep a finger or something on the end of the spring at all times to ensure it stays absolutely put.
The problem is that removing thgis hexagon will allow the contents of the LHM tank to syphon out so I recvommend disconneting the LHM suction pipe at the tank end and allowing the resitual LHM in the pump to drain before you fully remove the hexagon.
