I'll admit right away that I know a little less than nothing about vehicle electrics.
Anyhoo, the Xantia seems to have a small parasitic drain somewhere. It's not enough to flatten the battery overnight. Symptoms are that the little alarm LED in the drivers door and the window switch illumination is always on, even with the ignition off and the car locked. The electric windows also now work with no key in the ignition. Around the same time I also lost my RHS stereo speakers. Not sure if these problems are linked.
Any suggestions as to where I should start looking? My instinct says to start pulling fuses and see which one kills the live circuits, then trace the wiring on thet circuit to find the fault, but surely that's a bit too simple.
Any electrical gurus on here?
Prilliant03
98 Xantia HDi 110
02 Aprilia RST1000 Futura
Life is like a sewer...... You only get out of it what you put in.
- x 1504
Re: Any electrical gurus on here?
I'd have a look for broken wires in the tube going into the driver's door first....
citroenxm
- Fallen Hero
- x 70
Yup, Id second that.. Its hugely likely after a lot of door opening and closing the wires between the car and door break up, and its likely to be picking a live from else where....
Unfortunally on the xantia the harness is hard wired from the car right through to the door, so removing a door involves removing the door card and unplugging the harness from the various items and pulling it through..
Try pulling the wiring gromet back either way and check for broken wires.. But its highly likely indeed.
The annoying thing is though, where the wires have broken you cannot simply solder them back together, as they have weathered and deteriated solder does NOT stick to the wires.. The easyest way is to remove the door and re solder/join them further down by fitting new wires...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Chris570
- x 36
What he said but as a side just check the fuses are all in there correct homes and not bridging the constant live and switched (as in fuse 1 can be placed so that the radio stays on all the time) i'm not sure if its possible with others i've not looked but it maybe worth a checkcitroenxm wrote:Yup, Id second that.. Its hugely likely after a lot of door opening and closing the wires between the car and door break up, and its likely to be picking a live from else where....
Unfortunally on the Xantia the harness is hard wired from the car right through to the door, so removing a door involves removing the door card and unplugging the harness from the various items and pulling it through..
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 8457
Chris is speaking of the shunt 'fuse' marked SH and being grey in colour. It should straddle the F8 and F23 positions in the cabin fusebox. There should be no fuse in the F8 or F23 positions.Chris570 wrote:What he said but as a side just check the fuses are all in there correct homes and not bridging the constant live and switched (as in fuse 1 can be placed so that the radio stays on all the time) i'm not sure if its possible with others i've not looked but it maybe worth a checkcitroenxm wrote:Yup, Id second that.. Its hugely likely after a lot of door opening and closing the wires between the car and door break up, and its likely to be picking a live from else where....
