xantia Driveshaft nut size???
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
Hi guys,
just a quicky, What size is the driveshaft nut ion the Xant?? tried a quick search and couldnt find quite what i was after!
34/35/40mm ive no idea, haha!
thanks muchly in advance!
'58 C2 Code
'58 partner teepee outdoor
x 2938
Re: Xantia Driveshaft nut size???
I'm not sure if there are different sizes on the different shafts (there are two different sized ABS rings),the last time I did one on a 2001 2.0L HDI I bought a new 34mm socket for it.
x 8457
35mm or 1 and three eights inches also fits nicely...
Timmo
(Donor 2022)
x 168
Thanks chaps!
'58 C2 Code
davewithington
Unread post by davewithington »
Same size as a 2CV rear hub nut then?
