Timing Belt Kit
Gregg1100
x 5
Timing Belt Kit
Unread post by Gregg1100 »
I have just bought a FAI kit from our local motor factor. I don't know if others here have used them- the rollers look beefier than the original, brackets look a bit different, so will have to look closer when the original is removed. Has anyone else on the forum used FAI stuff before. Xantia 2 Sx 1.9TD
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
x 8457
Re: Timing Belt Kit
Yes, and they seem fine Greg. AS you say, they look well made and robust.
citroenxm
Fallen Hero
x 70
Re: Timing Belt Kit
Unread post by citroenxm »
xud engines are sooooo robust ive not actually ever changed and rollers on them as they are already all metal rollers.. My sx td 1994 xantia has 240k on it and well used rollers.. There is however no play in the bearings..
I have though used FAI kits on later hdi engines as they do have rubbish stupid plastic rollers and they are a lot stronger...
Good luck changing the xud tensioner one.. That spring is dammm strong! And its dam fiddle to get back in place..
Paul
A very sad...
1994 XM 2.1 d auto
