belt length without A/C
axford
Hi all, I have a 2001 citroen c5 110 8v. Does anyone know if I can take the air con pump off and fit a belt without it. I never use it and its screaching . If anyone has done this do they know the belt length and maybe where i can get one ? I had a look at a 306 hdi engine the other day and it looked right ????? Many thanks for your help
- x 8457
Re: belt length without A/C
Have a look at this thread. It relatres to a 1.9TD but I reckon it might well be applicable to the HDi the belt runs are very similar.
Basically, to work out the belt length, user a piece of wire over the run and then measure it. Deduct about 20mm or so for the tensioner to have enough travelk to be effective.
DickieG
- Monaco's youngest playboy
- x 33
Your point about the belt screeching makes me wonder whether the A/C pump is the source of the problem or whether it's the bottom pulley which is made of two pieces joined together by rubber, they are a well known cause of failure so I'd check that first, this can be done by painting a line across the two sections of the pulley then running the engine for a while to see whether the lines move (CitroJim tip
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 5688
Worth investigating, that's what's up with mine and needs sorting soon.DickieG wrote:Your point about the belt screeching makes me wonder whether the A/C pump is the source of the problem or whether it's the bottom pulley which is made of two pieces joined together by rubber, they are a well known cause of failure so I'd check that first, this can be done by painting a line across the two sections of the pulley then running the engine for a while to see whether the lines move (CitroJim tip)
Had the pulley, tensioners and idlers checked and a new belt fitted, screams like a banshee sometimes.
Ascending 11 floors of a multi story hospital car park was rather embarrassing to say the least.
Strangely enough the descent was silent.
axford
Its definately the a/c pump and i dont want to take the pump and belt off to measure until I have the correct one to put on if poss. Will do a bit more research on the 306 I think but if anyone knows for def that would be great. Thanks all so far though.
- x 8457
I reckon if you do as the linked thread says (salient part quoted below) and get a 6PK1130 you'll stand a very good chance of being OK.axford wrote:Its definately the a/c pump and i dont want to take the pump and belt off to measure until I have the correct one to put on if poss. Will do a bit more research on the 306 I think but if anyone knows for def that would be great. Thanks all so far though.
Getting an auxillary belt on and off an HDi is a piece of cake... I see no problem in popping it off to take a measurement...On the 1.9TD/2.1TD the A/C compressor can be bypassed by removing the eccentric (lower) tensioner complete and fitting a 6PK1130 belt running as follows:
HP Pump -> under automatic tensioner -> crank pulley -> alternator -> HP Pump.
The automatic tensioner will tension the belt and although there does not seem to be too much belt area in contact with the alternator pulley it seems to work OK.
I can't say for certain if this is good for the HDi but as it's a similar setup, it may well be OK.
axford
ok will give it a go. Actually I have awful trouble with the belt everytime its off even with the tensioner loose I have to turn the crank nut to get it on.Must be the wrong size.Fancy trying that belt though as it seems cheap enough.Many thanks for your help and will let you all know.
- x 8457
axford wrote:ok will give it a go. Actually I have awful trouble with the belt everytime its off even with the tensioner loose I have to turn the crank nut to get it on.Must be the wrong size.Fancy trying that belt though as it seems cheap enough.Many thanks for your help and will let you all know.
Ahh
It's easy to miss the spring tensioner as it looks just like another jockey wheel...
axford
Aha , that makes sense now . god if that works it'll save me loads of hassle. Thanks a million
