citroen c5 steering rack
axford
Hi all, I need to change the steering rack on a 2001 c5 hdi 110. Has anyone done this and if so is it poss to manouver out without dropping the sub frame ? Thanks for any info .
- x 2941
Re: Citroën c5 steering rack
According to the manual you do have to drop the subframe.
axford
I know but sometimes the manual tells you that the engine needs to come out so that you can replace a
wheel trim ! Anyone actually done this job ?
reblack68
What's the problem with the rack? If it's play on the inner joints you can buy them separately and they are quite easy to change.
Richard
Care of a 1994 205 D.
addo
- Sara Watson's Stalker
- x 95
axford
How more specific can i be . Its got an inch of play in it and needs replacing . Just got the new one and it comes apart just as the pinion goes into the rack which would defo give me a fighting chance of leaving the subframe alone ,this means the 6-7 inches going up to the pinch bolt can be taken off separately. Gonna get it on ramps 2 weekends time and see if its get attable. Will let you all know.
axford
update ,no chance at all ,it had to come a long way down
dowen
I changed the rack on my C5 v6 the sub-frame had to come down about a foot and it was still a struggle! I was on my own in the drive, so you will need to get it up as far as you can,on wood blocks.
Stock up on elastoplast, be prepared to invent a new swearing vocabulary.
Good luck. Dave.
Good luck. Dave.
