I'm having trouble with my 2002 C3 1.4 LX, its covered less than 40k and is having random starting problems.
Normally after 3-4 days the remote central locking wont work and the car wont start.
To solve, I manually use the key to open the drivers side door (which uses the central locking to unlock the other 3 doors) there is no alarm or sounds at all.
Once open I try to start the car, it just ticks over, no indication on starting, like the immobliser is stopping it?
This is when I have to open the bonnet and disconnect the lead and re-connect it, after that it all starts again no problem.
This is driving me crazy, and is very random, I cant replicate the issue...
It cant be the battery if I just disconnect and reconnect can it? if it was flat then it shouldn't start at all should it?
Samantha
