Citroen C5 1.6 Hdi Fault Code P0 1351
jmd
Unread post by jmd »
I would appreciate any advice members could offer towards solving the following problem.
My car a 06 Citroen C5 1.6Hdi shows Code P01351. I clear the code & it returns within a few days. What will it take to repair this problem, Is their a D.I.Y way of solving the problem, or is this an expensive repair.
I have got the following information from the internet -,
PO 1351 = IDM input circuit malfunction/ ignition Coil control circuit High Voltage SID 803 pre/post heating relay circuit relay not controlled & Glow Plug Supplied.
x 8457
Re: Citroën C5 1.6 Hdi Fault Code P0 1351
That code seems a bit vague, which is often the case when a universal code reader is used. Before going too fmuch further I'd try tio get the ECU read using a Lexia. That'll give a much clearer indication of the problem.
x 2938
The code means there may be a problem with the pre heat control relay, the advice given elsewhere is:
"Check the operation and output of the pre-heat control relay."
