Xantia Estate LHM leak - steering problem
NAM
Unread post by NAM »
Hi Chaps
Trust all getting ready for the festive season as I was when the STOP light came on this morning. My trusty MK2 Xantia Estate is currently on a ramp having a leak from the steering area looked at. Some mention of pipes not being available from Citroen (2000 model). :o
I await with baited breath as I was hoping to keep her going for another 12 months (and had just booked the MOT for 3rd Jan in full confidence of a pass!). :lol:
I'll update once I know what the diagnosis is but I just wondered if there is another outlet of said pipes should I need one and main dealer not be able to supply my local Cit specialist. I did have a look and there was a strong drip of the green suff on the front offside - just in from the wheel.
Santa might have to bring a new car on Sunday but I hope he can find a new bit of pipe. :)
Regards to all
Nigel
NEW 50 Shades of Grey C5 Tourer 2016 BlueHDi 2L VTR+
C4 (62) 1.6HDi VTR+ (Feb 2020)
Silver Dream Machine: C4 Hatchback, 1.6 SX HDi (07) (July 2013 - Feb 2020)
C5 Tourer Exclusive 09/2Ltr HDi (Oct 2012-Sept 2021 146K miles
Xantia Estate Mk2 1.8LX V-Reg/2000 173K miles.
x 8313
Re: Xantia Estate LHM leak - steering problem
That won't be a pipe with any luck. The pipe that goes and is allegedly NFP is the one that goes across the nearside wheelarch and off behind the engine..
From yur symptoms and where the leak is it sound like the pinion valve on top of the rack where the steering column joins has sprang a leak.
That's no worries at all. Pleiades can supply a recon one...
If there is a pipe issue then a repair, as long as it's not the rubber section, is quite possible with brazing kit...
NAM
Thanks Jim - just realised that I made a mistake on the location of said drip. It is on the front near side so does this means that the pinion valve idea is a no goer?
I should get the news tomorrow so I'll see what they say - hope it can be sorted as the rest of the car is going like a dream!
Nigel
x 8313
Yes, 'fraid so Nigel :( It'll be the pipe for sure if the drip is on the nearside in front of the wheel...
Still have a natter to Pleiades about it though...
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Sure it's not the return hose?
As to the feed pipe - I had mine remade by Pirtek (local hose franchise) after the mobile hose repairer's $150 repair failed at short notice. "Repair II" included an inline fitting so the parts could be installed without twisting the flex hose, then the inline fitting was nipped tight. So far, all good.
x 94
Unread post by citronut »
or if the leak is in the wheel arch behind the wheel i could be a leg/strut leak off pipe, which are avalible from GSF for not a lot of dosh, and a 10 minuite job to fit,
regards malcolm
NAM
Not sure which pipe it is but one is coming from Citroen - costs £150 so not cheap but looks like I'm heading for another 12 months of Xant Est motoring -just need to get her through the MOT.........
I'd almost given up and started looking at the new C5 Tourer (which looks good - has anyone tried one out?) but I will put new car ideas on hold.
Thanks for replies - I was ready to start talking to Pleides and others but with Santa on his way I just want it fixed.
NAM
Well she is now back on the drive - new Power Steering Pipe fitted (Citroen main stealers had one in stock). Took the garage 4 hours plus quite a bit of LHM so my wallet is suffering but fingers crossed for an MOT pass on Tuesday and another year of trouble free(ish) driving.
I have this ambition of getting to 200K miles on a petrol engine - we are within range now but at present milage it will take another 3-4 years and I don't know if she will last that long (or my wallet is deep enough).
Happy New Year to all - lets hope our cars's behave themselves for a bit.
Nigel
Carsten S
Unread post by Carsten S »
NAM wrote: I have this ambition of getting to 200K miles on a petrol engine
Well, that should not be a problem at all. Many of the Xantia's i've owned, that must around 20 now, have had between 300.000-400.000 kms in their life, and still goes perfect.
NAM
Hi Carsten - thanks for your encouragement! If things go well on Tuesday - MOT day then I will be looking at another year (at least!.
