Pressure regulator
davewithington
Pressure regulator
Unread post by davewithington »
Any one on here ever rebuilt a Xantia pressure regulator
I thought I'd get hold of a spare (same part number as some BXs) and have a play.
Deanxm
x 87
Re: Pressure regulator
Unread post by Deanxm »
yep, the main problem is they loose accuracy pressure output, you will need to test the valve on the car with a cheap pressure guage off of E-bay that reads up to at least 200bar as the cut in pressure should be 145bar and cut out 170bar. You will also need a bit of pipe made up to connect it to the valves output port.
Nothing unusual about them really.
CIMG3065 by Deanxm, on Flickr
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
