Hi folks,
My 2002 C5 HDI has started to jump from full beam headlights on, back to dipped beam without touching the stalk.
Sometimes it will stay on full beam for a few minutes before jumping back to dipped and sometimes it will stay on
full beam for only a few seconds!!
Is this the comms 2000 problem I've read about on the forum or is it just a problem with the stalk/switch?
Any ideas??
J.T.
Comms2000?
- x 1484
Re: Comms2000?
Both, probably! The COMS2000 IS the stalk / switch (it's an all in one unit covering both stalks and the rotary connector). Not cheap unfortunately, but provided you don't have ESP, it can be changed without a Lexia (requierd to re-initialise the steernig angle sensor).
JT
Re: Comms2000?
Thanks Richard,
The car is one of the earlier models so don't think it has ESP.
Is the comms unit difficult to change?
I presume it means removing the airbag and steering wheel.
JT
- x 1484
Re: Comms2000?
Never done it, but in principal: Remove air bag, remove wheel, remove column shrouds, remove COMS 2000. Refit is reverse of removal
JT
Re: Comms2000?
Ok. Thanks Richard.Sounds straight forward enough.
There again is anything ever straight forward with a Citroen??
JT
Chris570
- x 36
Re: Comms2000?
very often yes, i've found them very straightforward (XM excluded)
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
Citroenmad
- x 110
Re: Comms2000?
It is an easy thing to swap over, just be sure to follow the procedure for air bag removal (disconnect the battery and wait 20 minutes).
I had one C5 which would indicate left three times, then the indicator would stop and the headlights would come on. Pretty handy
The ESP button on C5Is is a mirror image of the cigarette lighter, just next to the gearlever. If you don't have that its a very easy swap.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
JT
Re: Comms2000?
Don't have any button like that, so will give it a go over Christmas.
Thanks for all the advice.
Happy Christmas folks.
JT
cachaciero
- x 9
Re: Comms2000?
If buying secondhand make sure you get the right unit they are different ESP /NON ESP and it is possible that there are differences AUTO Box / Manual don't have the data to hand but the Auto box needs to know if the car is turning which data it gets from the COM 2000 unit.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
Citroenmad
- x 110
Re: Comms2000?
Also, if buying second hand the stalks/comms2000 units differ with spec. So if you get one from an earlier C5 saloon and yours is a later one with a rear wiper it wont be on the stalk. etc.
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
