Has anyone else tried MEHR fuel filters on the XUD engine? I bought some off fleabay for about £3 each. They look nothing like normal filters. It's got a green plastic body with lots of holes in the top and what looks like rolled up paper in the bottom. I was a bit skeptical about it. I put one in yesterday, it was a tight fit, I hope it comes out again! Anyway, the results were very promising, acceleration was much better, cold starting was better (running on veg) and no hesitancy. I wonder how long it will last...
Anyone else tried them?
MEHR fuel filters
MPV
MEHR fuel filters
Synergie XUD9 - the "Duck-billed-clatterbus"
jgra1
- (Donor 2021)
- x 36
Re: MEHR fuel filters
hmm i was looking at these and got put off as they look so different.... although from your post MPV I may go for a batch
Jonh
Jonh
- x 8457
I'm not for one moment saying these are but a few years ago now there was a big batch of counterfeit filters of exactly this pattern in circulation in the UK. Even some of the big factors got caught out and so did I
basically, they were Ok for a while (days actually) and then the engine would display a range of symptoms of air ingress and so on. On inspection the filters were found to be badly swollen, the glue holding the media into the body melted and the media falling out. They could swell so badly as to lift the lid of the filter housing and be a bit hard to remove.
I'd check yours again soonish and check it's OK... I'm sure it will be but wise to check.
In my case the counterfeits were branded as HENGST, a well respected German maker. The only obvuius difference was the blue ink on the the box was a bit lighter colour than the genuine ones..
Here's the story from 2006...
Xaccers
- x 188
The filter paper compresses with the suction from the pump and it expands the walls so makes it difficult to pull out.
With the shifting filterpaper the ring of glue that is supposed to keep the paper in place breaks free and breaks up.
I used one for a couple of weeks before fighting to get it and the glue bits out of the housing before fitting a halfrauds type.
Got mine from ECP probably 3 years ago so pretty sure it was genuine.
Really not impressed with it.
DIY sphere tool
DIY sphere tool
