I'd like to change from auto to intermittent setting if it is possible to do so.
The way it is, auto wiper usually moves either at the same speed as 1st speed or faster.
Some have commented that it's because the glass is not clean or wipe is not good enough (or words to that effect) - if the wiper blades are installed a bit off (maybe too tight on the wiper arm maybe), it doesn't show (well, at least to my standard the windshield looks well wiped).
I also read somewhere that if the rain sensor is faulty, it reverts to intermittent setting by default (and I'm assuming intermittent speed is less than 1st wiper speed).
If I disconnect the rain sensor, what other features would I lose? Auto window winding when raining is cool but I don't think I have use for it.
cheers,
sam
C5 - Auto vs Intermittent Wiper
sonoramicommando
- x 5
2006 C6 Exclusive 2.7HDi
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
DickieG
- Monaco's youngest playboy
- x 38
Re: C5 - Auto vs Intermittent Wiper
If rain sensor wipers simply work as if they are on timed delay the cause is generally due to the sensor not being pressed hard against the screen, worth checking, if however you'd prefer to have timed delay wipers you now know what to do
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
sonoramicommando
- x 5
i'll disconnect and see i can live with it. i think it's possibly fogged up in there between the sensor & the glass.
thanks
thanks
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
waynedance
- x 8
I think the auto wipers work really well, easy to check sensor (well on mine). The surround arround the auto mirror just slides down, oh know this as my light sensor had moved and the lights were on during the day.
Volvo S80 D5.........
sonoramicommando
- x 5
the sensor seemed to have come off from the glass a little at the lower end.
how do i take it off completely, it looks pretty fragile. obviously i want to take it off, clean it and glue it back.
i disconnected yesterday, it's better than auto wiper that is not working well BUT it doesnt work as normal intermittent wiper should, i.e. speed dependent. it seems to sweep once every 5 seconds regardless of vehicle speed.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
DickieG
- x 38
If the sensor is like the one fitted to Xantia's there will be a yellow tag each side of the sensor which needs to be levered outwards to detach the sensor from the metal mounting plate. If the plate has started to come away from the screen don't use a standard/foam mirror mounting patch as its too thick and you'll end up back at square one, you need a very thin clear pad available from dealers or you might get away with using glass superglue.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
sonoramicommando
- x 5
thanks guys - i ll take the cover off and have a look again. maybe take a photo or two for reference.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
- x 5653
Mine just pull out quite easily. Just clipped in.
The newer ones with a single combines sensor may be different.
sonoramicommando
- x 5
the lower part of the sensor must have come off a little bit per the photo.
and it had a gel type clear adhesive over the whole sensor, as well as three clippy thingy latch onto the metal bracket.
i had to get the gel adhesive off because it got all dirty when i was taking it off - im going to push it in to the metal bracket and tape over it to see if it works any better.
- Attachments
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
Sl4yer
I take it that has auto lights as well? I've seen a C5 SX 2002 with the same sensor as the Xantia.
If the Xantia sensor is removed, the wipers won't work at all!
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
sonoramicommando
- x 5
yep - it has auto lights also.
i have scraped off the adhesive and clipped it back on. it seems to have clipped on pretty solid, not sure if i need adhesive there at all.
now all i need is rain to test it out.
it's a pity that sensitivity of the sensors cannot be adjusted.
1982 GSA Pallas
A couple of bikes
A boyracer car
1982 GSA Pallas
A couple of bikes
A boyracer car
