Clio diesel clutch
wornelly
Clio diesel clutch
Hi, i'm considering buying a clio 1.5 dci, but when I had a test drive the other day I found that the clutch was extremely heavy for a small car, so my question is is this a common problem and can anything be done to solve it or make it lighter many thanks in advance
antz
Re: Clio diesel clutch
yes it is a common problem and it will need a clutch fitting soon or the cable will snap..
hope this helps ..
hope this helps ..
Citroenmad
- x 110
I was driving a 2002 1.2 clio the other day, the clutch was very heavy. I then got into another 2002 1.2 Clio which had the same weight clutch. I got used to it after a while but its often a sign of a worn/aged clutch.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
