Part advice
i3
Part advice
Unread post by i3 »
Hey all,
could someone please advise me as to which of the following two pollen filters is suitable for a 1998 xantia mk2 exclusive 2.1td
this: http://www.ebay.co.uk/itm/Citroen-Xanti ... 336ead1363" onclick="window.open(this.href);return false;
or this: http://www.ebay.co.uk/itm/Citroen-Xanti ... 519a4fdf8d" onclick="window.open(this.href);return false;
thanks
'97 Xantia 2.1TD VSX - Left in 2011
'98 Xantia MK2 2.1TD Exclusive - Arrived in 2011
Gingerposer
x 6
Re: Part advice
Unread post by Gingerposer »
Best bet would be to measure your existing cabin filter and see which one matches it. It would probably also be worth checking with a local motor factor as they may not be more expensive than ebay and will be able to tell you exactly which one you need.
i3
Re: Part advice
Unread post by i3 »
how do i get it out?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
That's very interesting! Two sizes, slightly different. I've always had to cut about half an inch off the slanted edge for fitment.
x 94
Re: Part advice
Unread post by citronut »
i agree with Gingerposer check with a local motor factors as the price should not be much diferent to the first one,
and that second seems priced quite high,
regards malcolm
