Heated mirrors not working
Diabolical
Unread post by Diabolical »
Hi. Just noticed first proper frost that my Xantia heated mirror heating elements no longer work both sides but adjustment works OK.
Any ideas?
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
Stepto1
Re: Heated mirrors not working
Unread post by Stepto1 »
Remove the mirror glass,(prise apart the two little metal tails behind the glass at the top) and test that you are getting a current to the mirror with a multimeter or test lamp. If so then the elements have failed and you need a new glass. If not then the fault is downstream.
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
Diabolical
Drivers side mirror is NEW 6months ago so I guess it's not the elements.
citroencx.co.uk
Dommo
x 20
Unread post by Dommo »
Not trying to make you feel stupid, but you know they only come on with the heated rear window switch? And if so, does the heated rear window work?
Diabolical
Dommo wrote:Not trying to make you feel stupid, but you know they only come on with the heated rear window switch? And if so, does the heated rear window work?
Yes I know, heated rear window works OK.
I fitted the mirror so I'm coming to the conclusion it's my fault :oops:
Shall remove door card at some point and see what's up, could have missed plugging in plug for heated element.
citroencx.co.uk
i3
Unread post by i3 »
does every xantia have heated side mirrors?
'97 Xantia 2.1TD VSX - Left in 2011
'98 Xantia MK2 2.1TD Exclusive - Arrived in 2011
mirafioriman
Unread post by mirafioriman »
No, mine doesn't :(
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
i3
Unread post by i3 »
how do i find out if mine has?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Switch on the rear demister and feel if the mirrors get warm!
i3
Unread post by i3 »
ok. will i be able to feel an obvious difference?
i3
Unread post by i3 »
and if they are faulty? by the above test, i would i assume i don't have them. there must be another way of telling?
what spec had them?
thanks
addo
x 95
Looking your car up by VIN on "Service Citroën" is another way. I'd expect a facelift Exclusive to have them for sure.
x 8457
If you look carefully at a mirror, squinting at it helps, and when just misty you can sometimes just make out the heating elements if you're lucky.
I'd say that those cars with body-coloured mirror back covers are the heated ones. It's not truly model specific as I've seem SXs with them.
They are wired in parallel with the heated rear window so if that works then there is no reason why the mirrors won't - wiring through the doors aside...
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Heated mirrors were standard on SX models and above so VSX, Activa and Exclusives as well.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
