Xantia running temp.
aerodynamica
x 215
Unread post by aerodynamica »
When I first got the Xantia 12 weeks ago, the temp gauge hovered around the 80deg mark. But for the last few weeks it sits squarely at 60deg and rarely rises near 80 unless in traffic. fans work and the thermostat appears to be operating ok.
How does this behavior strike you? (obviously the outside temp has gone right down lately but this began weeks ago)
Graeme M
x 1480
Re: Xantia running temp.
Needs a new stat - they go baggy with age and leak too much water into the rad.
aerodynamica
x 215
Great thanks Richard for the speedy response! I did the 'feel test' on the stat rad hose and felt it heat up after a good 7-10 mins of idle - still outside the right amounts? I wonder if the stat housing will be the same swine of a thing as the CX's was with bolts snapping and suchlike..
Graeme M
addo
Sara Watson's Stalker
x 95
Unread post by addo »
In my experience, senders can get "blunted" with scale, too. The only temperature readings I trust are shot with a pyrometer or read off a thermocouple on my multimeter. It's nice when a gauge is accurate, but I wouldn't rely on them.
ecohouse1
x 3
Unread post by ecohouse1 »
I think mine runs cool from the guage too and I fitted a new stat and water pump as well. I have noticed that when after I have been in the car a few minutes the guages ALL drop a bit, eg fuel/temp etc - I think its something to do with the voltage! ie full tank drops to just under then back up to full when I next start up!! I reckon the temp guage is the same.
mirafioriman
Unread post by mirafioriman »
My 1.9D does run at about 80 on the gauge in colder weather but takes a long time to get there. I have replaced the thermostat in the past year which seemed to make little difference. Does it never get up to 80?
Former Proud owner of a 1994 Citroen Xantia 1.9d and BX 19RD
Now driving an Alfa 159 but god I miss the Xantia!
