Citroen Dispatch Heater
dudarus1
Unread post by dudarus1 »
Our van seems to have developed a new fault the heater blower only works when it wants to some times when you go over bumps it kicks in then randomly turns off. is there an easy way to bypass the switch and just have an on off switch or even better fix the original one.van is a 2006 1.9 diesel
thanks in advance
Mobile Towbar Fitting Service In The Midlands
http://www.jninstallations.co.uk" onclick="window.open(this.href);return false;
Cheapest Prices Guaranteed
bxzx16v
x 34
Re: Citroën Dispatch Heater
Unread post by bxzx16v »
Is the fan speed control slider functioning correctly ? Mine can be in the off position but can occasionally go into low speed , a spray of electrical contact cleaner may help
Mark
