Hi
In my Xantia the instrument panel illumination went out. I suspect that the fuse is blowen but I dont know which of the many is the one. there is no indication. could you please let me know which fuse is the rellevant one? or, if you know another possible reason - pls let me know.
Thanx.
Xantia mk2 fuse location
DickieG
- Monaco's youngest playboy
- x 33
Re: Xantia mk2 fuse location
Have you tried adjusting the dimming wheel under the steering column as that's the common cause of the dash lights failing.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Estately
- x 23
My handbook gives the instrument panel fuse as F12, a 20amp fuse, found in the fuses to the right of the steering wheel. I think the fuses in the fuse panel are numbered but if I am wrong it is the fuse in the right hand row and counting up from the bottom of just the double row of fuses, it is the fourth or the centre one in that row ie 3 fuses above and 3 below.
My car diagram shows three 20 amp fuses together in that block and the instrument panel is the middle one of the 20 amp fuses.
Hope that helps.
Hope that helps.
If it can happen it will.
- x 8457
F12 does a lot more than lighting up the instruments. Aircon and stop lights are just two functions. I'm sure if this was blown then there would be other symptoms apart from dark panel lights!!!
DickieG has the most likely cause. I've known the knob be moved by your knee to the extent that the lights are dimmed so much they go right out.. I do it regularly on my own cars...
atr
- x 6
Silly me... It was the dimmer, just as CJ and DickieG suggested. the lights are back on...
Thanx.
Thanx.
VertVega
- x 13
Sometimes it amazes me the amount of knowledge in this forum
