Citroen xsara 1.4i 1999 rear break system. help
superiorzbg
Unread post by superiorzbg »
Hi, I would like to convert my rear drum to brake discs. But unfortunately I cannot find any supplier selling a whole kit. Do you know any online shops pls?
car model: Citroen xsara 1.4i 1999 manual
Philip Cachia
x 94
Re: Citroën xsara 1.4i 1999 rear break system. help
Unread post by citronut »
i have never done this but would think it would be easier to swap the complete rear axle for one from a XSARA that has disc's already,
if you have any salvage yards local to you,
regards malcolm
x 8457
If the car is non-ABS then you may have to use the rear brake pressure compensators specifically for disc brakes. They may be different between disc and drum.
ABS sensors may be different and the handbrake operating mechanism may be too... As Malcolm says, better to source all you need from a donor.
In all honestly, rear discs are hardly worth having over a good drum setup. They give all sorts of trouble that drums don't for no real gain. Handbrakes and rear discs are never a good combination :twisted:
superiorzbg
Thanks, comments are appreciated :)
Philip Cachia
