Hi all,
Has anyone got a proper Citroen component location diagram for the ZX to hand?
I've tried to decipher where connectors could be in the Haynes by the general wiring location indicators on the legend.
Trying to find a 13 pin black connector which is somewhere between dashboard and interior? It states 13N B1. Not sure what B1 stands for for. It must be somewhere near the interior fusebox?
I think there is also a 14 pin black connector somewhere in the same vicinity too.
The annoying things is that I only did the heater matrix a few weeks ago and I could have noted a lot of this at the time but when you know it's a job that is going to take an inordinate amount of time to do, you don't really want to add to it!
More fool me!
Component Location Diagram Required - ZX Turbo Diesel
Rhothgar
- (Donor 2026)
- x 222
- x 94
Re: Component Location Diagram Required - ZX Turbo Diesel
what is the plug for maybe it goes onto the back of the fuse box,
regards malcolm
regards malcolm
Rhothgar
- (Donor 2026)
- x 222
It's all to do with tracing a central locking fault and knowing where the connectors are.
I'm not sure it does connect to back of fuse box primarily because it shows a wire coming from the fuse box to this connector on the wiring diagram.
