wiring blower
froggy
- (Donor 2026)
- x 4
wiring blower
Hi, I need to fit relay to the ignition switch on my mk1 Xantia. Can anyone tell me what size wire I will need to buy , or anything else that I need to buy , sorry for the obvious questions, but Iam very green electrically. cheers Terry . Its to solve the usual blower problems,
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Stepto1
Re: wiring blower
This is one of those jobs that's tricky to understand before doing it but seems easy after! The relay,(I used a 30A one from Maplins) just sits in the supply from the battery that used to go through the ignition switch. The only wires you need are to act as a trigger for the relay. I just used some wire I found in the garage. If you're not sure it will take it, double it up. If it looks up to it, I'm sure it will be. The circuit is already fused so all is well. Don't use the knackered contacts in the ignition switch but instead, follow the guide on here and use the new ones. Works a treat. Did mine about a month ago and no probs. Good luck.
Xantia SX 1.9TD Gone to the breakers
Xantia LX 2.0HDI Taxed and MOT'd at last!
Xantia 1.8 16V SX On loan to brother-in-law
Sportrack off road toy
Series One Land Rover
Thundercat race boat
dnsey
- x 19
Re: wiring blower
While the relay doesn't require much in the way of wire to feed the coil, you really shouldn't use anything suitable for less current than the fuse rating, otherwise a short circuit could still start a fireThe only wires you need are to act as a trigger for the relay. I just used some wire I found in the garage. If you're not sure it will take it, double it up. If it looks up to it, I'm sure it will be. The circuit is already fused so all is well.
- x 8327
Re: wiring blower
30A wire will be good but what I would advise is the investment in a very good crimping tool for the connections. These cheap ones you see all over the place are rubbish and can make unreliable joints...
As Steptoe says, a not a bad job at all. It's a lot easier than it looks...
froggy
- (Donor 2026)
- x 4
Re: wiring blower
Thanks all, Would Halfords be a good place to get the crimping tool Jim.
Terry
Stepto1
Re: wiring blower
Fair point about the wire. I meant any that looks beefy enough, not any old wire that's too thin.
I found the trick is to realise that there are not two red wires running from the ignition switch, just one red wire running through it. Once you get your head around that it's easy, just sort out the trigger to the relay. How Citroen ever thought it would last is beyond me.
lexi
- x 134
Re: wiring blower
Try here for crimp tool. http://www.vehicle-wiring-products.eu/V ... crimps.php" onclick="window.open(this.href);return false;
The one at £8.95 is ok.
I think the one at £3.95 may be the cheapo one to avoid that Jim refers to.
I prefer the non insulated terminals with the add on clear silicone rubber insulators.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 1484
Re: wiring blower
There should be enough heavy duty wire there already to do the load side of the relay - thin wire for the switching side is plenty good enough - the current is low.
froggy
- (Donor 2026)
- x 4
Re: wiring blower
Thanks guys. Where is the best place to source the " 40 amp relay " . cheers Terry .
Terry
- x 8327
Old-Guy
- x 24
Re: wiring blower
...and a professional crimping tool. I think mine was about £15 - it makes crimping so much easier and you get a neat strong crimp every time.CitroJim wrote:Any good factors will have relays Terry...
