Shouted myself one of the fancy billet trolley jacks for home use - four wheeled variety, not the three-legged type. So far, quite impressed (1500kg rating). Local price was $220, or about £145.
Definitely not up to fulltime workshop use, but for a hobbyist it seems a viable alternative to a proper workshop jack - without the killer weight.
Bit of an indulgence (Tool buy)
Re: Bit of an indulgence (Tool buy)
seems quite a lot compaired to this one Adam
http://tinyurl.com/crbtwkd" onclick="window.open(this.href);return false;
regards malcolm
regards malcolm
I always lusted after one of THESE handy for sunken XM's but in the end got one of These, not as flashy but works well and got it for £80 i think, strange my engine hoist cost the same though...................
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
For recovering sunken Citroens, I have a standard wheel changing jack, as originally supplied with, I think, the Rover 800 series, It has a strange 'rocking' action as it lifts, which enables it to get under the lowest of jacking points. Once high enough, I swap to a standard trolley jack.
I also have a very ancient jack very like a short Acrow prop, with bevelled gear drive at the base, which is ideal for supporting engines etc.
