Flashing stop light
KennyW
x 164
Flashing stop light
Unread post by KennyW »
Hi All,
Returning home a couple of nights ago, the red stop light and the red light on the temp gauge starting flashing, then stopped after a short distance.
I checked the car the next day and nothing obvious but on Monday morning notice a leak, coming from the A/C compressor at the clutch, possibly a seal gone.I don't use the air con.
Is this the reason for the flashing red lights :lol:
Any suggestions :?:
Kenny
C3 1.4 petrol (SWMBO)
x 8343
Re: Flashing stop light
Nothing to do with the aircon compressor Kenny. This is an HDi so everything is under control of the engine ECU. It gets its information from the coolant temperature sensor in the side of the cylinder head. If the sensor was bad, the cooling fans would be running at top speed as well as the light being on...
Hopefully just one of those things but if it persists it'll need a Lexia session to see if the engine ECU stored any faults relating to the sensor..
KennyW
x 164
Thanks Jim, I could'nt figure out how the compressor would affect anything. Will check the fluid levels again but I think it was probably citroelectrics again :wink:
Kenny
Derekofpriory
Unread post by Derekofpriory »
Does the Temp. gauge work all the time? I had your symptoms and could get the light to flash to order by turning on Aircon, then counting to ten, the light then flashed, turn off Aircon and count to 7 flashing stopped. The problem was found to be in the multiway connector on the nearside wing below the battery, lots of waggling gave an unreliable contact, bridging a wire across the connector cured my problem. Probably nothing to do with your problem but who knows where the juice goes!!
Cheers Derek B.
our car spent Friday afternoon and Monday morning in the electrics area of the Factory!!
x 1485
If the AC is on and the fans don't run the STOP / temp light flash. Not forgetting that the AC on a MK2 comes on automatically when demist is selected.... Stop with temp light on can also indicate low coolant level.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I had the same thing occur on my previous HDi, the cause was corroded terminals on one of the fan relays located between the fans.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Chris570
x 36
Unread post by Chris570 »
can also be the level in the header tank, or the sensor going duff
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
CitroJim wrote: I'm a pink fairy
A 1/3 of Team WFA 'Clarkson'
KennyW
x 164
Thanks for all the replies,
The air con is not switched on but there is a problem in that area anyway.
Checked coolant level it was down a bit and topped up same but lights have not come on prior to and after top up.
Will leave it mean time
Kenny
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
DickieG HAS answered your question!
Its a fault with the "SLOW RUNNING" of the cooling fans, of either one of the relays between the fans, or a wire in the area behind the passenger headlight, and fusebox area...
in MY experiance and argument, not ALL S2 Xantias have auto Air con when Windscreen de mist is selected! ONLY cars after W reg... And Ive had a few S2 Xantias aswell... even my current V reg HDI Exclusive does not do it, but my mums Y reg HDi and an X reg SX HDi Ive just sold both do it..
Paul
A very sad...
1994 XM 2.1 d auto
KennyW
x 164
Thanks Paul,
Will check the relays.
Kenny
Jacob2112
Unread post by Jacob2112 »
Be interested in the outcome here too. Have a 2001 Xantia HDi 110bhp on 89k which, surprise, surprise, started flashing its STOP light and temperature light at me last Monday.
Ran the car for 20 mins and local garage did too with no signs of rising temperature (sat around 96deg) although fans didn't cut in. Idled fine. However, the flashing lights stopped when the interior light came on (I had the driver door open). Since then completed a 110 mile round trip with no problem, during which we discovered that flashing will stop if blower fan is not switched on manually, OR the blower fan is set on Auto so that it's operation is determined by inside temperature.
Now - '01 Black Xantia HDi Forte 110bhp 89,000m
Ex- '97 Red Xantia 1.9TD SX 132,000m
'91 Grey BX 1.9D Meteor
Viva la Xantia, Au revoir Xanity
