Xantia Clock
acrowot
Xantia Clock
Unread post by acrowot »
Should the clock illuminate when the sidelights are on, if so how accessible is the bulb to change it.
1996 Xantia TDSX
SGould
Unread post by SGould »
Cannot remember for sure so need to check but I think the clock does illuminate in mine with the side lights
Homer
x 16
Unread post by Homer »
I think yes.
I know I can read mine at night anyway.
Nikolaymk
Unread post by Nikolaymk »
I don't think it illuminates. It never have on mine anyway.
acrowot
Sorted this today it does illuminate it comes on with the side lights, its a pig to change though, steering wheel off, parts of the dash and radio, horrible.
puddle jumper
Unread post by puddle jumper »
access the clock by pushing out the switch to the right of the clock then you can push the clock out from the back with your finger 5 minutes no problem.
Thregwort
Unread post by Thregwort »
Hey, Puddle Jumper - brilliant!!
The front of the switches just pry away [if you push down from the top edge and lever behind with a blunt blade] revealing the bulb.
However, I can't get the rest of the switch out and there's a couple of tiny springs...
How did you get the body of the switch to the right of the clock to come out? [It's the hazard warning light switch].
