RFV engine
atr
x 6
RFV engine
Unread post by atr »
Hi
I want to replace the engine of my 2001 Xantia - RFV engine. I was offered a RFV engine from a Peg 406. is it the same engine? would it fit?
Thanx.
Btw. does anyone has technical stuff/manual of the engine, since I intend to rebuild the engine.
x 8457
Re: RFV engine
It should do. They're the same basic engine. Some ancillaries may be a little different but fundamentally, the engine should be OK...
To be honest, the Haynes BoL usually tells you all you need to know about engine rebuilds in fairly good detail.
atr
x 6
Re: RFV engine
Thanx CJ, but the Haynes doesn't cover the 2 liter engine. so, if anyone knows an info source....
