Random alarm sounding - Xantia II
rmunns
x 9
Unread post by rmunns »
Over the past two weeks we have had three occasions when the alarm has sounded at random. This is after the car being locked using the 'blip'. Any ideas, please?
miked
x 6
Re: Random alarm sounding - Xantia II
Unread post by miked »
Spider nesting in the ulrasonics?
You can disable the ultrasonics if you hold down the alarm button on the dash until the light comes on solid before leaving the car.
That will then tell you if it is a problem with the interior sensors (ultrasonics) or a door/bonnet/boot open sensor fault.
i3
Unread post by i3 »
ah, am having the same problem i think...
and thanks miked, i will try that!
'97 Xantia 2.1TD VSX - Left in 2011
'98 Xantia MK2 2.1TD Exclusive - Arrived in 2011
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
on the estate the boot lock has worn over time and no longer pusheds the pin switch for the alarm in enough to say its closed, if you lock it with the plip (before the wife boke it!!) and hold the pin in was fine, but let the pin go and it would chirp as you locked it.
'58 C2 Code
'58 partner teepee outdoor
rmunns
x 9
Thanks, I'll check this.
lexi
x 133
Unread post by lexi »
What do you mean by this? Hold the boot down?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Timmo
(Donor 2022)
x 168
no, sorry, pop the alarm switch off the boot lock (plastic clip that holds it on) and hold the pin on the microswitchy bit in when you lock the car with the remote, if it still chirps on locking then isnt the boot lock!
'58 C2 Code
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
With the boot lock there are a few things that can occur, the switch slips off it's locating slot or the switch pin snaps off, with the lock itself the hole the pivot pin sits in wears causing the latch to sit at an angle preventing the switch pin from being depressed.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
