For a 2003 c5 2.0 hdi manual i belive citroen recommend Total BV 75W – 80W gearbox oil,
Is this correct, is this the best stuff to use, it appears to be mineral based,
Would there be any benefit (in terms of long life and smooth operation),
to using some of the newer more pricey fully synthetic oils out there, (any suggestions)
Thanks sam
gearbox oil
411514
- (Donor 2017)
- x 39
gearbox oil
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
- x 94
Re: gearbox oil
as far as im aware the BV spec gear oil was specialy produced for PSA gear box's,
and it seems detrimental to put anything elss in there,
it also is far more dosh than the run of the mill gear oil, but if other types cause damage to you box it aint worth useing them,
regards malcolm
regards malcolm
VertVega
- x 13
Re: gearbox oil
Always used Total BV 75W80 which is the right stuff411514 wrote:...i belive Citroën recommend Total BV 75W – 80W gearbox oil ...
