DIY tracking
Stekelly
DIY tracking
Unread post by Stekelly »
Was thinkign about this the other day so had a root on Ebay and came across this http://www.ebay.co.uk/itm/TRACKACE-TRAC ... 336d2a8e88" onclick="window.open(this.href);return false; after also watchign Ed China do it :-D Seems simple enough. The only thing is, woudl the wheels not need to be on some sort of dolly to let them turn a bit while your adjusting the track rod end?
SaabC5
Re: DIY tracking
Unread post by SaabC5 »
Correct. they are normally put on a round plate with a pivot underneath that allows you to adjust the track rod end correctly.
x 1240
Re: DIY tracking
Unread post by Peter.N. »
For many years I have used something even simpler than that, it a length of threaded rod slid into a tube. I adjust it to length so that it just touches the front edge of the tyres about level with the top edge of the bottom rim them move it to the same postion at the rear of the tyre and check the gap - or lack of it. I have used this method on CXs, BXs and XMs, my front tyres last about 30k and wear evenly.
x 2941
Re: DIY tracking
As for the need to let the wheels pivot all you need is a sandwich of grease between a couple of steel plates to sit the wheels on.
electronmirror
x 30
Re: DIY tracking
Unread post by electronmirror »
Cheaper than a dollop of grease and two steel plates........rip a dozen pages out of a glossy magazine that SWMBO has finished reading. :lol:
The china clay ( kaolinite ) used in the production of the glossy paper makes for two very slippery surfaces.
Several years ago I bought a Gunsons Trak-rite device which has always given sterling service, but I do like the simplicity of Peter N's suggestion.
Ted
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
MPV
Re: DIY tracking
Unread post by MPV »
After the hassle I've had with the "super laser modern alignment machine" at my local tyre place this week, I was also wondering if it could be done DIY...
3 times I've been back and it still pulls to the left.
Synergie XUD9 - the "Duck-billed-clatterbus"
x 1240
Re: DIY tracking
Ah, if its pulling to the left that's unlikely to be a tracking error unless its very severe, its more likely to be due to uneven tyre wear or the camber angle being incorrect which could be due to worn bushes or something bent. One of my XMs pulls to the right, I have never been able to find the cause but it doesn't wear the tyres excessively so I learned to live with it.
dnsey
x 19
Re: DIY tracking
Unread post by dnsey »
Tracking does seem to be one of those simple things which somehow retains a strange mystique.
I use a similar method to Peter's.
My tracking tool is an extending tent pole, but something like a clothes prop would do just as well. Adjust it for a good fit between rims on the 'shorter' side, and the extra gap on the 'longer' side is easily measured (or estimated - as the C5's toe is zero to something, I'm happy with a slight rattle!).
I bet DIY tracking gives more accurate resullts than many chain garages - I've seen some horrific errors in the past!
GB
Re: DIY tracking
Unread post by GB »
dnsey wrote:I bet DIY tracking gives more accurate resullts than many chain garages - I've seen some horrific errors in the past!
Agreed. Usually the hi tech tracking equipment is great, but the operator just CBF (can't be f.).
Looks like my C5 is still on it's original factory tracking (78K miles), and the tyre wear is great.
I'll be getting a new set of tyres in March and was considering tracking adjustment as well, but I guess if it ain't broke don't fix it.
05 C5 VTR 2.0 HDI
115k
RichG
Re: DIY tracking
Unread post by RichG »
Stekelly wrote:Was thinkign about this the other day so had a root on Ebay and came across this http://www.ebay.co.uk/itm/TRACKACE-TRAC ... 336d2a8e88" onclick="window.open(this.href);return false; after also watchign Ed China do it :-D Seems simple enough. The only thing is, woudl the wheels not need to be on some sort of dolly to let them turn a bit while your adjusting the track rod end?
I bought a Trackace a few months ago. The price seemed high for what it was but it is well made and did exactly what it said on the tin.
As my tracking was within limits I did not have to adjust it. I did check it three times, after moving the car back and forwards again and the reading stayed the same.
The instructions are very detailed on how to ensure that the car 'sits' correctly before checking it.
Richard
1998 Xantia 1.9TD Estate (Sold - replaced with Skoda Octavia (sorry))
x 2941
Re: DIY tracking
electronmirror wrote:Cheaper than a dollop of grease and two steel plates........rip a dozen pages out of a glossy magazine that SWMBO has finished reading. :lol:
The china clay ( kaolinite ) used in the production of the glossy paper makes for two very slippery surfaces. Ted
Funnily enough I don't have any women's magazines in my workshop but I do have steel and grease. :-D
Clogzz
x 40
Re: DIY tracking
Unread post by Clogzz »
I have brooms, curtain rods, a rake and chalk in my garage … all good measuring tools. :twisted:
x 1240
Re: DIY tracking
Adjustable ones? :-D
Clogzz
x 40
Re: DIY tracking
Two of the curtain rods are, the others get the chalk marks. :-D
DickieG
Monaco's youngest playboy
x 38
Re: DIY tracking
Unread post by DickieG »
There's a £15 discount available on that ATM direct from Trackace = £77.49 delivered, very tempting.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
