Hello all,
can anyone bare some light on why my cooling fans are running all the time, they run with engine on but not ingnition only, its a 2000 2.0hdi 90bhp, this model only has a single coolant temperature sensor so ive kinda ruled that out as everything else is ok (no warning lamps and temp reads fine). if i pull the fuse (21) for the air con it kills the fans, now im lost,
xsara 2.0hdi fans running constantly
- x 1056
Re: xsara 2.0hdi fans running constantly
Do they run all the time if the interior blowers are switched off ?
Danbrown26
not sure il check tomorrow
- x 1480
If the direction is set to demist, chances are it's calling for AC. hence the fans are on all the time - normal!
Danbrown26
that makes sence, if it was set to demist would the a/c light be on or not
- x 1056
It depends on the car wether the A/C light comes on or not, on a xantia it doesent, on a mk 2 xsara it definitely does. Either way if you turn the blowers off it should cut the A/C & therefore the cooling fans.
Danbrown26
yup that was it, on demist it puts the air con on with no light and starts the fans, user error. thanks for your help saved me a lot of messing around
