xantia 1.9td BMF 2 shorted
weg
Unread post by weg »
Hi, my xantia 1.9Td vsx (1995) BMF 2(B) shorted.When 40A maxi fuse was installed, the dash board light will ON instantly even no ignition key was inserted.The ON dash lights is same as when ignition key is in Start/motor position.Psl give some advise.Thanks
spider
x 77
Re: Xantia 1.9td BMF 2 shorted
Unread post by spider »
First thought is the ignition switch itself is shorted. If you remove the column cowling and trace the wiring back from the switch you will find one or two multiplugs, unplug these so the ignition switch is not in effect connected at all.
Now try the fuse again. If it behaves properly (no dash lights etc) then you probably want a new ignition switch assembly. It may be easier to get one from a breakers although get the key as well.
Andy.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
spider wrote:It may be easier to get one from a breakers although get the key as well.
The electric switch can be removed from the barrel assembly and swapped.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
weg
Thanks you very much Andy and DickieG for the info.Will do it soon.
Regards
Weg
spider
x 77
Was not aware of that. The last one I looked at (probably on 309 a few years ago) was or appeared to be one unit, dismantling might of resulted in an excess of brass / copper spring plates falling out. They had already supplied a replacement so I did not look that closely I'll admit at the older one.
I don't think you can buy the switch separately for the older generation of vehicles though. :?:
Andy.
weg
Hi, is Berlingo(3 connectors) ignition switch compatible with Xantia 1.9 Td,pls give some advise.Thanks in advance.
spider
x 77
weg wrote:Hi, is Berlingo(3 connectors) ignition switch compatible with Xantia 1.9 Td,pls give some advise.Thanks in advance.
Not sure probably not as different 'generation' , you may find a later 306 or a Xsara is suitable though.
Andy.
