My boot will not open , was intermitttent now almost permanent.
I reset the BSI and it worked for a while.
Tested the switch and motor driven lock, both function fine.
I have also repaired the tailgate window and this now works.
see http://users.skynet.be/sky83161/sven/openingc5.pdf" onclick="window.open(this.href);return false;
This fix involves putting a power line on the rear window switch.
Is there a possible fix for the boot using this method?
Also anyone have a wiring diagram for this as Haynes is pretty poor.
Fish.
